8 years agoHelp multiplier vhdl
Hi everyone!
I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The multiplying is in a register with parallel output and the multiplier in a shift register of length m with serial output, the first bit to be the least significant. Each bit of multiplier, in his turn, multiplies by multiplying all, so that with operations multiplication is performed. I've the problem with the shift register with serial output, because I don´t know how to do it!! I'm learning VHDL right now, and I've never work with this hardware description language. Please if anyone can help me, I'd be very grateful. Thank you!!
