8 years agoHelp multiplier vhdl
Hi everyone! I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The mul...
8 years ago --- Quote Start --- well Tricky that might work but is too tricky for beginner, after all I can just say y = a*b I assume it is exercise that gets more and more compact under pressure...great --- Quote End --- Thank you kaz and Tricky, finally before I read your answers I have solved it in the way that kaz as told me. So I've understood it very well. Thank you so much for the help!!!!
