8 years agoHelp multiplier vhdl
Hi everyone! I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The mul...
8 years agoIm feeling pretty generous today. I hate seeing overly complicated case statements.
I think the following code does what you're trying to do:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
entity prueba2 is
port (
A : in std_logic_vector( (7 downto 0);
B : in unsigned (7 downto 0);
inicio : in std_logic;
clk : in std_logic;
reset : in std_logic;
q : out unsigned (2 downto 0);
resultado : out unsigned (15 downto 0)
end prueba2;
architecture behavioral of prueba2 is
signal cuenta : unsigned(2 downto 0);
signal y : unsigned(15 downto 0);
begin
multi : process (clk, reset)
begin
if reset = '1' then
y <= (others => '0');
elsif rising_edge(clk) then
if inicio = '1' then
cuenta <= cuenta + 1;
end if;
if A /= x"00" then
if A( to_integer(cuenta) ) = '1' then
Y <= Y + ( resize(B, y'length)*(2**to_integer(cuenta)) );
end if;
end if;
end if;
end process;
q <= cuenta;
resultado <= y;
end architecture;
