9 years agoHelloWorld - compiler error, not able to generate hardware
Recently I bought the DE1-SoC Board for trying OpenCL with it. - I set up the environment variables like suggested in the "DE1SOC_OPENCL.pdf" - I have a valid licence. - I have downloaded the BSP for the Board After trying to compile a .cl -File (the vector_add example from the intel site) with the command: aoc device/vector_add.cl -o bin/vector_add.aocx --report --board de1soc_sharedonly I get the error: Compiler Error, not able to generate hardware. The .log file gave me following error-text: ... info (21057): implemented 12069 device resources after synthesis - the final resource count might be differentinfo (21058): implemented 13 input pins
info (21059): implemented 45 output pins
info (21060): implemented 57 bidirectional pins
info (21061): implemented 10410 logic cells
info (21064): implemented 1528 ram segments
info (21065): implemented 1 plls
info (21071): implemented 1 partitions
info: quartus prime analysis & synthesis was successful. 0 errors, 65 warnings
info: peak virtual memory: 1136 megabytes
info: processing ended: mon may 15 07:23:33 2017
info: elapsed time: 00:00:32
info: total cpu time (on all processors): 00:00:31
error (281039): finished parallel synthesis of 1 partition(s). 1 partitions did not finish parallel synthesis because there were errors
error (281040): partition "system_acl_iface_hps_hps_io_border:border" did not complete synthesis due to errors
info (144001): generated suppressed messages file /home/developer/workspace/opencl_intel_tutorial/opencl_example_vector_soc/vector_add/bin/vector_add/top.map.smsg
error: quartus prime analysis & synthesis was unsuccessful. 2 errors, 581 warnings
error: peak virtual memory: 1575 megabytes
error: processing ended: mon may 15 07:26:48 2017
error: elapsed time: 00:04:42
error: total cpu time (on all processors): 00:04:56
error (293001): quartus prime full compilation was unsuccessful. 4 errors, 581 warnings
error: flow compile (for project /home/developer/workspace/opencl_intel_tutorial/opencl_example_vector_soc/vector_add/bin/vector_add/top) was not successful
error: error: error(s) found while running an executable. see report file(s) for error message(s). message log indicates which executable was run last.
error (23031): evaluation of tcl script /home/developer/intelfpga_lite/16.1/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful
error: quartus prime shell was unsuccessful. 11 errors, 581 warnings
error: peak virtual memory: 806 megabytes
error: processing ended: mon may 15 07:26:49 2017
error: elapsed time: 00:04:50
error: total cpu time (on all processors): 00:05:04 Google said that that "Error: Peak virtual memory: 806 megabytes" means that i´m using to much logic elements, but its just the vector-add example so I´m quite confused. I hope someone can point out whats the problem. Thanks :)
