9 years agoHelloWorld - compiler error, not able to generate hardware
Hello, Recently I bought the DE1-SoC Board for trying OpenCL with it. - I set up the environment variables like suggested in the "DE1SOC_OPENCL.pdf" - I have a valid licence. - I have dow...
9 years ago --- Quote Start --- Installing Quartus Prime Standard edition (Version 16.1.2) and using OpenCL SDK Version 16.1.0 solved the problem. Thanks for your help HRZ :) --- Quote End --- I have the same problem. I have following versions of openCL and Quartus. Should I update the version of OpenCL? Is there any command to update the OpenCL version? Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler Version 16.1.0 Build 196 Copyright (C) 2016 Intel Corporation [krunal.patel@AOCLDev hello_world]$ quartus_map --version Quartus Prime Analysis & Synthesis Version 16.1.2 Build 203 01/18/2017 SJ Standard Edition Copyright (C) 2017 Intel Corporation. All rights reserved.
