9 years agoHelloWorld - compiler error, not able to generate hardware
Hello, Recently I bought the DE1-SoC Board for trying OpenCL with it. - I set up the environment variables like suggested in the "DE1SOC_OPENCL.pdf" - I have a valid licence. - I have dow...
9 years agoYour compilation is failing during synthesis which is very strange. Please post the output of the following commands:
aoc --version quartus_map --version Also Terasic has two BSPs for this board. One is for Quartus v14.0, one is for v16.0. Which one are you using? P.S. OpenCL in Quartus v16.1.0 is broken. Make sure you are using v16.1.1 or v16.1.2.
