9 years agoHelloWorld - compiler error, not able to generate hardware
Hello, Recently I bought the DE1-SoC Board for trying OpenCL with it. - I set up the environment variables like suggested in the "DE1SOC_OPENCL.pdf" - I have a valid licence. - I have dow...
9 years agoTanks for repliying
aoc --version: Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler Version 16.1.2 Build 203 Copyright (C) 2017 Intel Corporation quartus_map --version:Quartus Prime Analysis & Synthesis Version 16.1.2 Build 203 01/18/2017 SJ Lite Edition Copyright (C) 2017 Intel Corporation. All rights reserved. I have installed the V16 BSP. I had Quartus v16.1.0 installed and updated it to Version 16.1.2.203 today. But i got "compiler error, not able to generate hardware" again. I have the Quartus Prime Lite edition. Could this be a problem? Since updating Quartus i´m not able to find the "quartus_sh_compile.log" do you know why this is the case? Thanks for your help :)
