Hello. I'm new to FPGAs/CPLDs, and am doing a project with the MAX V 5M160ZE64A5N CPLD and am getting timing failures with a 100MHz clock.
I removed the clocks from all inputs and outputs, as they were not required and actually causing application issues. And I introduced a second timer on each of the 6 sub-circuits, as using one single timer was also causing application issues. I am using the data signal as the clrn control for the flip-flops as again, for my application, I would like to clear them when this signal is low - is this how this function is intended to be used?
I've experimented with disconnecting the clock signal from some of the flip-flops in order to play with the fanout. Although the number of flip-flops connected to the clock signal did change the slack, there was no correlation between the fanout number and the amount of slack - ie. reducing the fanout didn't necessarily reduce the negative slack and increasing fanout didn't necessarily increase negative slack.
Many thanks
