Hello, I would like to know how do I code fixed point arithmetics (add/sub/divide/multiply/abs/round) for cyclone V FPGA device. I am coding VHDL on Quartus prime standard edition version 18.1
Hello DKras4
IP blocks for calculations can be found as indicated above.
Included one of my test projects I am working on, it does calculations in floating point and fixed point with ip blocks (and a natural logarithm ln()). You might get some inspiration out of it. All is targeted Cyclone V DE10_STANDARD.
If you want to do only simple fixed point calculations, you can code it directly in VHDL, no need for IP blocks.
Below a timer component that effectively counts clock pulses to wait for a certain period of time.
The objective of the block is to extend the signal "Ein" for a certain period of time.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;entity ent_sa_timer is
generic( clk_f : in real:=50.0E6;
t : in time:=1sec);
port( clk : in std_logic;
reset_p: in std_logic:='0';
ein : in std_logic;
aus : out std_logic);
end entity;
architecture arch_sa_timer of ent_sa_timer is
signal ctr : integer:=0;
signal T_Clock : time:=1.0/clk_f*1sec;
signal ein_local : std_logic;
begin
process (clk, reset_p)
begin
if rising_edge(clk) then
if ein_local='1' then
ctr<=ctr;
elsif ctr>0 then
ctr<=ctr-1;
end if;
ein_local<=ein;
end if;
end process;
aus<='1' when ctr>0 else '0';
end architecture;The line ctr<=ctr-1 decreases the value of ctr with 1 each time there is a rising_edge of clk.
You can do all kinds of mathematical functions with it mod * + / etc. and you can combine other variables as well.
No need to parametrize Ip blocks for these simple functions.
Johi.
