MATRIX7878
2 years agoHDMI IP not generating example
Hello, I am trying to generate an HDMI TX/RX (if need be one at a time, so be it) example from the HDMI Intel FPGA IP. I run the generate example, but after around 15-20 minutes, I get met wit...
ZH_Intel
2 years agoHi Drew,
Thank you for your reply.
We suggest you to use the latest version of Quartus which is 23.3 or use the workaround stated in the article below:
Regarding to your question, Could I also have run out of disk space?
Yes disk space could be one of the factor that could cause error when generating a design example.
Hope this answers your question.
Do you still have further inquiries on this issue?
Is there anything else I can help you with regards to this case?
If there is no further inquiries, I will transition this thread to community support.
Thank you.
ZH_Intel
