MATRIX7878
2 years agoHDMI IP not generating example
Hello, I am trying to generate an HDMI TX/RX (if need be one at a time, so be it) example from the HDMI Intel FPGA IP. I run the generate example, but after around 15-20 minutes, I get met wit...
MATRIX7878
2 years agoHello,
I am using Quartus 23.2. That is the problem. I should upgrade to fix the error. I am using Windows 11. I should be able to create the files then. Could I also have run out of disk space? I do not know if the example goes through the whole synthesis and fitter process, but that might also explain an error.
Thank you,
Drew
