HDMI IP not generating example
Hi Drew,
Thank you for your patience.
We have check the design example generation, and we could not replicate your error from our end.
We found no issue when generating the design example.
Q1. May I know which version of Quartus you are using?
Q2. May I know which operating system that you are running your Quartus software on?
Please be inform that there is a known bug for Hdmi design example VHDL variant for Quartus Version 23.2, You may refer to below KDB for more information and workaround.
Do note that when you select custom development kit under the design example tab, you will need to make some modification in order to make the design example work. (assign pin assignment in qsf file).
Attached is my generated design example (Quartus version 23.3) for your reference.
Hope this answers your question.
ZH_Intel
