HDMI IP giving an error about clock
Hi Drew,
Good day.
Thank you for your reply.
I have found the same error as what you are experiencing.
After running some test, we found that this error occurs when selecting "Custom Development Kit" in the target development kit option in IP Parameter Editor in Quartus software.
Screenshot Screenshot2
To workaround for this issue, you may generate the example design by selecting either "No Development Kit" or "Agilex 7 FPGA Development Kit"
in the target development kit option in IP Parameter Editor.
If you are using custom development kit, you can generate with above selection then you will need to re-assign the pin assignment in order for design example to work on you custom development board.
I have filed in this case to our internal team and they are running investigation on this.
This bug will be fixed in the future release of Intel® Quartus® software.
Thank you Drew and appreciate your input in reporting this error.
With that, do you still have further inquiries on this case?
Is there anything else I can help you with regards to this case?
ZH_Intel
