Has anyone succeeded running Questa Starter with license file?
HI all,
After some days when it was not possible to generate license file for Questa Starter it is finally possible to do it. But unfortunately the license file that is sent over the email does not allow running Questa Starter.
After trying to run Questa there is an error message saying:"Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem."
If license file (fixed) is generated with host Id, the lmutil lmstat says "Error getting status: No SERVER lines in license file. (-13,66)"
Is there ANYONE that can help on this? The documentation is quite poor, because for example in some places it says that Questa starte does not require license file (which is not true).
Does Intel actually care about customers who want to use this version of the software??
- RFI
Another dead end to this issue. If we can't even get the starter edition working, why would we risk a purchase of Questa? Can someone at Intel fix the "Self Service" Licensing Center or post a solution that works please? I have received no email either - the SSLC is an endless non-functional loop:
email recieved after 12 hours with a link to where I started:
Link takes me back here and around and around we go:
(chat support is no help - points to this forum)
- Fooanon
What a disaster.
- ni4et
I first met flexlm almost 30 years ago and have used it on several systems and architectures in a big national laboratory environment. I thought I knew all the tricks. Every thing looks right, the suggested diagnostic doesn't complain. Uncle already!!!!
- ni4et
I never give up but I also admit to stupid mistakes. The problem was solved by switching the license type to "FIXED", settin LM_LICENSE_FILE to the new one, and rebooting. Hope this helps.
- Tyler4
Does the License have to be stored in a specific directory or does LM_LICENSE_FILE just have to point to wherever it is stored? Still having this problem and can't find a solution anywhere.
- p-d
I am seething, I have been doing this for over a decade and never has the experience of setting up a basic simulation environment been so maddening, I have already wasted the better part of a working day trying to guess why questa_fse can't checkout a license.
Tried on Ubuntu 22.4 (which, surprise, is apparently supported by Quartus but not by Questa), RHEL7, RHEL8, RHEL9... both 22.1 standard and 22.4 pro.
There is no way Gelsinger can turn this ship around anymore.
- xLFC
I am having issues with this too on Ubuntu 22.04. I got a FIXED license in the self-service portal, set the LM_LICENSE_FILE environment variable as instructed, but still cannot launch Questa Starter from Quartus Prime Lite. It just doesn't launch anything.
I tried to launch Questa manually from the terminal by running "vsim" (I can do this for ModelSim Starter), but I get a licensing error, as seen in the snippet below (note that I replaced my MAC address with "xxxxxxxxxxxx"). It seems "lmutil lmdiag" isn't doing anything useful.
It looks to me that the license file I am receiving from the self service portal is incomplete. It doesn't seem to have any keys on it, nor a "FEATURE" entry, like in other sample files I have seen online. I believe there are two entries because I generated a second license in an attempt to fix the issue.
Can someone at Intel check if the licensing portal is doing the right thing? I think I followed all the steps to create the license, and the online help is not very helpful at this point anymore. Is this even a valid license file? If not, why?
luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ ./vsim Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmutil lmdiag' to diagnose the problem. Unable to checkout a license. Vsim is closing. ** Error: Invalid license environment. Application closing. luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ echo $LM_LICENSE_FILE /home/luis/intelFPGA_licenses/xxxxxxxxxxxx_License.dat luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ cat $LM_LICENSE_FILE # Intel Corporation Software and/or Intellectual Property License File # Issued 03 February 2023 # Upgrade to these products will no longer be available after the Maintenance Expiration # date unless licenses are renewed. # Fixed Node License # Primary Machine Name-Tesla # Primary Machine ID-NIC ID xxxxxxxxxxxx # Companion ID-N/A # Companion ID 2-N/A # Product License Summary: # Questasim*-Intel FPGA Starter Edition, 1 Seat(s) # - Maintenance Expiration of 2024.02 # - License Expires 03-Feb-2024 # Questasim*-Intel FPGA Starter Edition, 1 Seat(s) # - Maintenance Expiration of 2024.02 # - License Expires 03-Feb-2024 ################################################################################ # FEATURE START # This is license file for Questasim*-Intel FPGA Starter Edition # Number of seat licenses is 1 # License Expires 03-Feb-2024 # FEATURE END ################################################################################ # FEATURE START # This is license file for Questasim*-Intel FPGA Starter Edition # Number of seat licenses is 1 # License Expires 03-Feb-2024 # FEATURE END ################################################################################ # End of Intel Corporation Software and/or Intellectual Property License File. Issued 02/03/2023 luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ ./lmutil lmdiag lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved. FlexNet diagnostics on Fri 2/3/2023 22:16 ----------------------------------------------------- License file: /home/luis/intelFPGA_licenses/xxxxxxxxxxxx_License.dat ----------------------------------------------------- luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$- rols
I have the same issue, the license file sent to me also has no SERVER line, no FEATURE line and the 'activation key' I can see in the online portal doesn't appear in the file, in fact there's nothing in there apart from commented-out lines so I'm quite sure we're getting totally blank license files.
Is there anything anyone's found which works? Is there a template license file I can fix up with my own data and try?
I thought for a while this was probably my fault and I was missing something but now I'm fairly sure that it's just the license portal mailing out a blank license.
- OttoVonMetz
Same issue here. The license file generated is all comments:
# Primary Machine Name-<DELETED_FOR_POSTING>
# Primary Machine ID-NIC ID <DELETED_FOR_POSTING>
# Companion ID-N/A
# FEATURE START
# FEATURE END
# FEATURE START
# FEATURE END
- rols
Having checked out a few other posts here it seems fairly likely that many people are seeing the exact same issue, we're all just getting blank license files. Is there actually a place to get some support or because it's a free license the only support is to post here and hope an Intel employee take pity on us?
For my part I've moved back to modelsim using a post from 2 years ago telling you how to get it to run in a 64 bit operating system but that's honestly pretty sad. I've also posted my 'license' file here in the hope that an employee looking at the thread will have plenty of examples to send to the license team to get the license server fixed. And yes I tried lots of different things which is why I now have 3 non-licenses in there. I think we're all agreed here now that those license files are all comments and there are no actual license lines in them.
# Primary Machine Name-******
# Primary Machine ID-NIC ID ******************
# Companion ID-N/A
# FEATURE START
# FEATURE END
# FEATURE START
# FEATURE END
# FEATURE START
# FEATURE END
# End of Intel Corporation Software and/or Intellectual Property License File. Issued 02/03/2023- rols
and just to add one more datapoint for anyone who comes here .. this is a snippet of an example license file from Intel's support site
####################################################################### # FEATURE START # The following is a license file for the Quartus PRIME PRO Edition Fixed # Number of seat licenses is 1 # No license expiration date FEATURE maxplus2 alterad 2021.05 permanent uncounted B36133371D28 \ HOSTID=e4a4716b48d8 SIGN="1A0F EECF 699E A64A 1E3A 83D1 BADC \ 7763 B15D 98FA EF7F A371 E02F 4D9F D9CF 0BCE 2A9C 2650 20FA \ 42CF ABD8 006A D037 DA2C 703B 9CFC 43E5 1A01 0C56 4D6D" FEATURE quartus_pro alterad 2021.05 permanent uncounted 46499B9E717E \ HOSTID=e4a4716b48d8 TS_OK SIGN="08EF B762 CF6A 18CC FF95 B124 \ 2FB0 F8F0 7A43 CAFE C88E DC28 5AC4 5F69 FFFB 1C1C DBF6 7A79 \ 87E7 FFEF D8C2 F96F 461A 0D38 DB4B 4E5B 840E F3F6 F314 4DE9" # FEATURE ENDthis is what it's SUPPOSED to look like. Obviously this license file is for a different product and is just an example but yes I think we can reasonably accurately state that the self-service portal is emailing out totally bogus license files. So it's just not going to work.
- TRoa
Same empty license files. Contain only comments. No licenses.
Dear Intel, please do something about it.
- Balzac_Guan
Same empty license file with only comments.- majoh
I also got a empty license file with only comments.
- regul
same problem
- fvartzi
same problem
- oa_reply
Yep - same problem, waste of an hour.
