Has anyone succeeded running Questa Starter with license file?
I am having issues with this too on Ubuntu 22.04. I got a FIXED license in the self-service portal, set the LM_LICENSE_FILE environment variable as instructed, but still cannot launch Questa Starter from Quartus Prime Lite. It just doesn't launch anything.
I tried to launch Questa manually from the terminal by running "vsim" (I can do this for ModelSim Starter), but I get a licensing error, as seen in the snippet below (note that I replaced my MAC address with "xxxxxxxxxxxx"). It seems "lmutil lmdiag" isn't doing anything useful.
It looks to me that the license file I am receiving from the self service portal is incomplete. It doesn't seem to have any keys on it, nor a "FEATURE" entry, like in other sample files I have seen online. I believe there are two entries because I generated a second license in an attempt to fix the issue.
Can someone at Intel check if the licensing portal is doing the right thing? I think I followed all the steps to create the license, and the online help is not very helpful at this point anymore. Is this even a valid license file? If not, why?
luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ ./vsim Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmutil lmdiag' to diagnose the problem. Unable to checkout a license. Vsim is closing. ** Error: Invalid license environment. Application closing. luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ echo $LM_LICENSE_FILE /home/luis/intelFPGA_licenses/xxxxxxxxxxxx_License.dat luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ cat $LM_LICENSE_FILE # Intel Corporation Software and/or Intellectual Property License File # Issued 03 February 2023 # Upgrade to these products will no longer be available after the Maintenance Expiration # date unless licenses are renewed. # Fixed Node License # Primary Machine Name-Tesla # Primary Machine ID-NIC ID xxxxxxxxxxxx # Companion ID-N/A # Companion ID 2-N/A # Product License Summary: # Questasim*-Intel FPGA Starter Edition, 1 Seat(s) # - Maintenance Expiration of 2024.02 # - License Expires 03-Feb-2024 # Questasim*-Intel FPGA Starter Edition, 1 Seat(s) # - Maintenance Expiration of 2024.02 # - License Expires 03-Feb-2024 ################################################################################ # FEATURE START # This is license file for Questasim*-Intel FPGA Starter Edition # Number of seat licenses is 1 # License Expires 03-Feb-2024 # FEATURE END ################################################################################ # FEATURE START # This is license file for Questasim*-Intel FPGA Starter Edition # Number of seat licenses is 1 # License Expires 03-Feb-2024 # FEATURE END ################################################################################ # End of Intel Corporation Software and/or Intellectual Property License File. Issued 02/03/2023 luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$ ./lmutil lmdiag lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved. FlexNet diagnostics on Fri 2/3/2023 22:16 ----------------------------------------------------- License file: /home/luis/intelFPGA_licenses/xxxxxxxxxxxx_License.dat ----------------------------------------------------- luis@tesla-ubuntu:~/intelFPGA_lite/22.1std/questa_fse/linux_x86_64$
- rols3 years ago
I have the same issue, the license file sent to me also has no SERVER line, no FEATURE line and the 'activation key' I can see in the online portal doesn't appear in the file, in fact there's nothing in there apart from commented-out lines so I'm quite sure we're getting totally blank license files.
Is there anything anyone's found which works? Is there a template license file I can fix up with my own data and try?
I thought for a while this was probably my fault and I was missing something but now I'm fairly sure that it's just the license portal mailing out a blank license.
- OttoVonMetz3 years ago
Same issue here. The license file generated is all comments:
# Primary Machine Name-<DELETED_FOR_POSTING>
# Primary Machine ID-NIC ID <DELETED_FOR_POSTING>
# Companion ID-N/A
# FEATURE START
# FEATURE END
# FEATURE START
# FEATURE END
