esantana
1 year agoGND connection restriction between Logic Lock regions
Hello, I am trying to realise a design with 3 logic regions (using logic lock). All of them are reserved regions (no connections between them). However, it is a conection outside the regions. It i...
sstrell
1 year agoCan you show some code that shows this implementation? Logic 0 does not need to route to a specific location on the device unless you've added some code that would define it. You say "GND" is not defined as a signal, but the Chip Planner screenshot you show says otherwise unless there is some other logic you've defined that is causing this issue.
