13 years agogetting error in digiclock project..help me..
hii.
i am doing project on altera de1 board on digi clock. when i compile the program i am getting error in the following line (c1: sec_clk port map(clkm,rstsec,sflag); it shows node c1 instantiates undefined entity'sec_clk' pls help me.. thanks. code is given below: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity DigiClock is port( clkm: in std_logic; rst,setm,seth: in std_logic; z: in std_logic; op: out std_logic; op0,op1,op2,op3: out std_logic_vector(6 downto 0) ); end DigiClock; architecture clock of DigiClock is component sec_clk Port ( clks : in std_logic; rsts : in std_logic; ops : out std_logic ); end component; component min_clk Port ( clkmi : in std_logic; rst : in std_logic; opm : out std_logic ); end component; component manu_clk Port ( set : in std_logic; clk : in std_logic; opu : out std_logic ); end component; component seg7 port(m: in integer range 0 to 10; num: out std_logic_vector(6 downto 0)); end component; signal mflag: std_logic; signal sflag: std_logic; signal a: integer range 0 to 10; signal b: integer range 0 to 6; signal c: integer range 0 to 10; signal d: integer range 0 to 3; signal x: std_logic; signal hrt: std_logic; signal t: std_logic; signal u: std_logic; signal v: std_logic; signal rstsec: std_logic; signal mi: std_logic; signal hr: std_logic; begin c1: sec_clk port map(clkm,rstsec,sflag); c2: min_clk port map(sflag,rst,mflag); c3: manu_clk port map(setm,clkm,mi); c4: manu_clk port map(seth,clkm,hr); op<=sflag; delayt: process(clkm,z) begin if rising_edge(clkm) then t<= z; end if; end process delayt; clockmin: process(x,rst,u) variable m0: integer range 0 to 10:=0; variable m1: integer range 0 to 6:=0; begin a<=m0; b<=m1; hrt<= '1' and u; if rst='0' then m0:=0; m1:=0; elsif falling_edge(x) then if m0/=9 then m0:= m0+1; u<='0'; elsif m0=9 and m1/=5 then m0:=0; m1:= m1+1; u<='0'; elsif m0=9 and m1=5 then m0:=0; m1:=0; u<='1'; end if; end if; end process clockmin; selecter: process(t,hr,mi,mflag,hrt) begin if t = '0' then x<=mi; v<=hr; rstsec<='0'; else x<=mflag; v<=hrt; rstsec<='1'; end if; end process selecter; clockhr: process(v,rst) variable m2: integer range 0 to 10:=2; variable m3: integer range 0 to 3:=1; begin c<=m2; d<=m3; if rst = '0' then m2:=2; m3:=1; elsif rising_edge(v) then if m2/=9 and m3=0 then m2:=m2+1; elsif m2=9 and m3=0 then m2:=0; m3:=m3+1; elsif m2/=2 and m3=1 then m2:=m2+1; elsif m2=2 and m3=1 then m2:=1; m3:=0; end if; end if; end process clockhr; z0: seg7 port map(a,op0); z1: seg7 port map(b,op1); z2: seg7 port map(c,op2); z3: seg7 port map(d,op3); end clock;
