16 years agoGenerated Clocks using TimeQuest
I couldn't find a specific constraints area on the forum so I hope I'm in the right place.
I have two clocks that are generated by outputs of a counter. The counter is clocked at 100MHz, and I take bit 1 as a 25MHz and bit 2 at a 12.5 MHz clock. I am trying to tell the tools about these clocks. I have no reference to these clocks in my qsf file. In the sdc file I put : create_clock -period 10 -name CLOCK100M [get_ports {CLOCK100M}] create_clock -period 40 -name LCLK [get_ports {LCLK}] create_generated_clock -divide_by 4 -source [get_ports {CLOCK100M}] -name CLOCK25M [get_registers {fpga_test_ports:fpga_test_ports1|sClockCounter[1]}] create_generated_clock -divide_by 8 -source [get_ports {CLOCK100M}] -name CLOCK12M [get_registers {fpga_test_ports:fpga_test_ports1|sClockCounter[2]}] The problem is I then get the following error message: Warning: Node: raw_data_capture:raw_data_capture1|sClockCounter[1] was determined to be a clock but was found without an associated clock assignment. Warning: Node: raw_data_capture:raw_data_capture1|sClockCounter[2] was determined to be a clock but was found without an associated clock assignment. I have looked through the online documentation but I can't find what I am missing. Can anyone help?
