You should be able to program that device via the flash programmer within Eclipse. You'll need to put a small Nios design together that includes an EPCS Serial Flash Controller. Once programmed into the FPGA you can use the Flash programmer for program a wider variety of serial flash parts.
Not quite as simple as using the .jic I'm afraid :( Cheers, Alex - Altera_Forum
--- Quote Start --- Not quite as simple as using the .jic I'm afraid :( --- Quote End --- I agree ! But thank you for your help !
