Gated clock conversion and state machines
I'm having issues with gated clock conversion if there is state machine in gated clock tree. As soon as I remove fsm or select synthesis option to not infer state machines the gated clock conversion works well.
Any hints ?
Reason given when conversion doesn't work is 'Found unsupported gate'.
- ak6dn
What do you mean by 'gated clock tree'?
I have run state machines at an effective lower frequency than the master clock by using an enable signal for the state machine.
Ie, something like this:
reg [3:0] count = 0; reg [3:0] state = 0; reg enable = 0; always @(posedge clk) begin count <= count+1; enable <= (count == 0); end always @(posedge clk) begin if (reset) state <= 0; else if (enable) begin case (state) 0: state <= 1; 1: state <= 2; ... default: state <= 0; end endso that in this case the state machine triggers every 16 clocks based on the value in count.
- robert_g
My problem is related to gated clock conversion to clock enable. By gated clock tree I meant all the logic which is clocked by gated clock.
- ak6dn
Well I am not sure what you mean by a 'gated clock' then. Can you provide a simple example of your logic in verilog?
To me, a 'gated clock' means inserting logic in a clock signal path to control the usage of the clock.
That is not a recommended design practice for FPGAs. Better to distribute a common clock and use enable signals on registers.
- RichardT_altera
You may checkout the Clock-Gating Methods below, see if it meet your design requirement :
- RichardT_altera
Since there are no feedback for this thread, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos and select the best solution.
