9 years ago
frequency meter on cyclone IV E ,without display frequency
hi everybody.
sorry for my english.
I ask for your help for released an simple frequency meter with vhdl (i am newbie on FPGA):
https://alteraforum.com/forum/attachment.php?attachmentid=14027&stc=1
Input
"ref_clock" is 50 MHz periode 20ns of cyclone IV E.
"signal" is mesured signal from encoder
Output
cycle of test errors every 1 sec
if frequency >= 1000 Hz ==>error1 = 1 //1 is logic HIGH
if frequency >= 2000 Hz ==> error1 = 1 and error2 = 1
else error1 = 0 and error2 = 0 //0 is logic LOW
thank you.
    thank you Tricky, josyb.
    Tricky, how to do it in the simplest way possible.
    josyb, I didn't understand half of the code.
    I told you that I was newbie in(FPGA VHDL...)
    Here is my code
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity freq_meter is
    port (
      i_ref_clock    : in  std_logic; -- 50 MHz
      i_signal       : in  std_logic; -- from encoder
      o_error1       : out std_logic;
      o_error2       : out std_logic);
    end freq_meter;
    architecture freq_meter_arch of freq_meter is
    begin
    --  CLOCK REFERENCE domain
    variable clock_secand_decounter : integer := 50000000;
    variable i_signal_counter : integer := 0;
    if(clock_secand_decounter<=1) then
    	if(rising_edge(i_signal)) then
    		i_signal_counter <=i_signal_counter+1;
      		if(rising_edge(i_ref_clock)) then
    			clock_secand_decounter <= clock_sec_dec -1;
    		end if;
    	end if;
    end if;
    if(clock_secand_decounter >= 1000)then
    	o_error1='1';
    	o_error2='0';
    	elsif(clock_secand_decounter >= 2000)then
    	o_error1='1';
    	o_error2='1';
    else
    	o_error1='0';
    	o_error2='0';
    end if;
    end freq_meter_arch;
    Yes I know there is a lot of errors
    Here is the timeline.
    https://www.alteraforum.com/forum/attachment.php?attachmentid=14030
    The syntax errors should be easy enough for you to fix by referencing a vhdl text book.
    But there are more fundamental errors - eg. Having a rising edge inside a rising edge will never occur in reality. I suggest you work through a tutorial that covers basic logic to try and understand what is wrong with your code.
