9 years agofrequency meter on cyclone IV E ,without display frequency
hi everybody. sorry for my english. I ask for your help for released an simple frequency meter with vhdl (i am newbie on FPGA): https://alteraforum.com/forum/attachment.php?attachmentid=...
9 years agothank you Tricky, josyb.
Tricky, how to do it in the simplest way possible. josyb, I didn't understand half of the code. I told you that I was newbie in(FPGA VHDL...) Here is my code
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity freq_meter is
port (
i_ref_clock : in std_logic; -- 50 MHz
i_signal : in std_logic; -- from encoder
o_error1 : out std_logic;
o_error2 : out std_logic);
end freq_meter;
architecture freq_meter_arch of freq_meter is
begin
-- CLOCK REFERENCE domain
variable clock_secand_decounter : integer := 50000000;
variable i_signal_counter : integer := 0;
if(clock_secand_decounter<=1) then
if(rising_edge(i_signal)) then
i_signal_counter <=i_signal_counter+1;
if(rising_edge(i_ref_clock)) then
clock_secand_decounter <= clock_sec_dec -1;
end if;
end if;
end if;
if(clock_secand_decounter >= 1000)then
o_error1='1';
o_error2='0';
elsif(clock_secand_decounter >= 2000)then
o_error1='1';
o_error2='1';
else
o_error1='0';
o_error2='0';
end if;
end freq_meter_arch;
Yes I know there is a lot of errors Here is the timeline. https://www.alteraforum.com/forum/attachment.php?attachmentid=14030
