17 years ago
Forcing FPGA signal using SignalTap Logic Analizer
Hi.
I am looking some possibility to force Altera's internal signals (wires or registers) using Quartus tools.
As I remember, in Xilinx development tool ISE I could assign values to internal signals using ChipScope tool. I suppose, Altera should also have similar possibility.
Someone used it? And how?
Thank you.
Dima
    Yes, it is called SignalTap.
    It is included free with the subscription version of your tools.
    There should be free WEB based training on the Altera Web site under education.
    --- Quote Start ---
    --- Quote End ---
    Yes, I familiar with SignalTap Embedded Logic Analizer.
    But this tool can only acquire data from FPGA, and I didn't find any option to FORCE Altera internal registers with SignalTap, I could only to sample it.
    The only option to force an internal signal is to use a Source & Probe instance and add a multiplexer to the design, that switches each individual signal to a source & probe output.
    --- Quote Start ---
    ... use a Source & Probe instance...
    --- Quote End ---
    For the documentation, see the Quartus handbook, Volume 3, Section V, Chapter 17, "Design Debugging Using In-System Sources and Probes".
    Depending on what you are trying to accomplish, the ECO design flow might work. It lets you make/change some routing connections, change LUT contents, etc. without running a full recompilation. That's covered in Volume 2, Section IV, Chapter 13, "Engineering Change Management with the Chip Planner".
    I think, that's the tool I looked for - Source & Probe.
    I'll check it out.
    Thank you.
