17 years ago --- Quote Start --- ... use a Source & Probe instance... --- Quote End --- For the documentation, see the Quartus handbook, Volume 3, Section V, Chapter 17, "Design Debugging Using In-System Sources and Probes". Depending on what you are trying to accomplish, the ECO design flow might work. It lets you make/change some routing connections, change LUT contents, etc. without running a full recompilation. That's covered in Volume 2, Section IV, Chapter 13, "Engineering Change Management with the Chip Planner".
