12 years ago
For loop, array and a step motor, VHDL
I'm trying to implement a sequence in order to use a step motor using VHDL. Since I'm really new to VHDL I can't see what's missing in my code. I want to loop through an array to give the different steps to my variable named motor.
I'd appreciate any help.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity main is
    Port ( motor : out  STD_LOGIC_VECTOR (3 downto 0));
end main;
architecture Behavioral of main is
    type my_array is array (0 to 6) of std_logic_vector(2 downto 0);
    signal secuencia : my_array;
    secuencia := ("0000", "0001", "0010", "0011", "0100", "0101", "0110", "0111");
begin
    variable i : std_logic:= '1';
    for i in secuencia' range loop
      motor <= secuencia(i);
   end loop;
end Behavioral;
These are the errors:
ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 12: Syntax error near "secuencia".
ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 15: Syntax error near ":=".
ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 16: Syntax error near "loop".
ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 18: Syntax error near "loop".
ERROR:ProjectMgmt:496 - 4 error(s) found while parsing design hierarchy.
    Looking the code it seems you are a C programmer. The for loop statement in vhdl it's different from the for sentence of C. For loop is not a sequential statement. It is used when you need to copy paste many times a circuit cell ( iterative circuit ).
    Probably you're tried to explore the 8 output value you write in secuencia. A counter may solve it:
    signal sec_reg, sec_next : unsigned(2 downto 0);
    begin
    process( clr_n, clk )
    begin
    if( clr_n = '0' ) then
    sec_reg <= ( others => '0' );
    sal_reg <= "0000";
    elsif( clk'event and clk = '1 ) then
    sec_reg <= sec_next;
    sal_next <= sal_next;
    end if;
    end process;
    sec_next <= sec_reg + 1;
    motor <= sal_reg;
    process(sec_reg)
    begin
    case sec_reg is
    when "0000" =>
    sal_next <= "0000";
    when "0001" =>
    sal_next <= "0001";
    -- complete the rest
    end case;
    end process;
    end Behavioral;
    There something missing in this code. To drive a stepper motor you need to slow down the clock.
    Hey! Thank you so much for your answer. Actually I'm more into C so finally I decided to use a PIC. Anyways, I am going to try it again using VHDL.
    Here is what I was trying to do:
    char values = {0B01000, 0B01100, 0B00100, 0B00110, 0B00010, 0B00011, 0B00001, 0B01001};
      void motor(){
        short i;
        for (i = 0; i<7; i++){
          PORTC= values;
          Delay_ms(1);
    Thanks again for your time!! :)
    --- Quote Start ---
    --- Quote End ---
    Sorry to be a pedant, but a for loop IS a sequential statement. It will work exactly like it's C counterpart in the right situations - but only in simulation. The Synthesisor will unroll the loop and create parrallel logic as you describe, but the behaviour of a for loop can be important in testbenches. If you want "sequential" code inside a for loop, you can use a variable instead of a signal updating between iterations (but then you'll get a long chain of logic).
    look I developed this code for a stepper motor with a sequence and I hope you serve :)
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    entity mtrpas is
    port(
    clock,reset:in std_logic;
    clkout:inout std_logic;
    push_l ,push_r: in std_logic;
    pasos2: out std_logic_vector(3 downto 0);
    pasos: out std_logic_vector(3 downto 0));
    end mtrpas;
    architecture archi_mtrpas of mtrpas is
    CONSTANT max: INTEGER := 50000000;
    CONSTANT half: INTEGER := max/10;
    SIGNAL count: INTEGER RANGE 0 TO half;
    begin
    PROCESS
    BEGIN
    WAIT UNTIL clock'EVENT and clock= '1';
    IF (count < max) THEN
    count <= count + 1;
    ELSE
    count <= 0;
    END IF;
    IF (count < half)THEN
    clkout <= '0';
    ELSE
    clkout <= '1';
    END IF;
    END PROCESS;
    process(push_l ,push_r,reset,clkout)
    variable cuenta: integer range 0 to 5:=0;
    begin
    if clkout'event and clkout='1' then
    if(reset='0') then
    cuenta:=0;
    else
    if(push_l='1') then
    cuenta:=cuenta+1;
    if(cuenta=5) then
    cuenta:=0;
    end if;
    end if;
    if(push_r='1') then
    cuenta:=cuenta-1;
    if(cuenta=0) then
    cuenta:=4;
    end if;
    end if;
    end if;
    end if;
    case cuenta is
    when 0=> pasos<="0000";pasos2<="0000";
    when 1=> pasos<="1000";pasos2<="1000";
    when 2=> pasos<="0100";pasos2<="0100";
    when 3=> pasos<="0010";pasos2<="0010";
    when 4=> pasos<="0001";pasos2<="0001";
    when others => null;
    end case;
    end process;
    end archi_mtrpas;
    Can you give an example?:
    --- Quote Start ---
    --- Quote End ---
