12 years agolook I developed this code for a stepper motor with a sequence and I hope you serve :)
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity mtrpas is port( clock,reset:in std_logic; clkout:inout std_logic; push_l ,push_r: in std_logic; pasos2: out std_logic_vector(3 downto 0); pasos: out std_logic_vector(3 downto 0)); end mtrpas; architecture archi_mtrpas of mtrpas is CONSTANT max: INTEGER := 50000000; CONSTANT half: INTEGER := max/10; SIGNAL count: INTEGER RANGE 0 TO half; begin PROCESS BEGIN WAIT UNTIL clock'EVENT and clock= '1'; IF (count < max) THEN count <= count + 1; ELSE count <= 0; END IF; IF (count < half)THEN clkout <= '0'; ELSE clkout <= '1'; END IF; END PROCESS; -------------------------------------------- process(push_l ,push_r,reset,clkout) variable cuenta: integer range 0 to 5:=0; begin if clkout'event and clkout='1' then if(reset='0') then cuenta:=0; else if(push_l='1') then cuenta:=cuenta+1; if(cuenta=5) then cuenta:=0; end if; end if; if(push_r='1') then cuenta:=cuenta-1; if(cuenta=0) then cuenta:=4; end if; end if; end if; end if; case cuenta is when 0=> pasos<="0000";pasos2<="0000"; when 1=> pasos<="1000";pasos2<="1000"; when 2=> pasos<="0100";pasos2<="0100"; when 3=> pasos<="0010";pasos2<="0010"; when 4=> pasos<="0001";pasos2<="0001"; when others => null; end case; end process; end archi_mtrpas;
