17 years agoThank you so much for your comments. I have modified it as follows:
Library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; Library altera_mf; use altera_mf.altera_mf_components.all; entity floatadd is port( inA,inB : in std_logic_vector(31 downto 0); inclk : in std_logic; out1 : out std_logic_vector(31 downto 0) ); end floatadd; architecture add of floatadd is begin fp_add : altfp_add_sub generic map ( DIRECTION => "ADD", ROUNDING => "TO_NEAREST", width_exp => 8, width_man => 23, pipeline => 11 ) port map ( clock => inclk, dataa => inA, datab => inB, result => out1 ); end add; I tried to compile it and it is working. Have to simulate it and check with the results. But is this make senses to you?
