saasha
4 months agoFIR IP configured for Interpolation
Why does my Altera FIR IP, configured for interpolation by 80, produce the expected outputs when I provide 3 input samples, but fail to produce the expected behavior when I provide 10 input samples? ...
saasha
4 months agoHi Jeffc,
I had tried this one, this was giving expected number of outputs.
JeffC_Altera
4 months agoTo be clear - does this allow you to move forward right now? The functionality of "tready" is only a pass-through of the tready on the source side (input). Per the documentation, it's not a function of the current status of the internal FIR. So, you need to create your signaling to match the system behavior, which is what I articulated in the drawing. If you are seeing bursts of data coming in, you might need to add a simple FIFO/buffer that pulls data out at the 1-in-80 and absorbs bursts on the write side (not to exceed a net rate of 1-in-80, of course).
