saasha
4 months agoFIR IP configured for Interpolation
Why does my Altera FIR IP, configured for interpolation by 80, produce the expected outputs when I provide 3 input samples, but fail to produce the expected behavior when I provide 10 input samples? ...
saasha
4 months agoI am using Quartus prime lite 25.1 version.
But I was not able to see tready go low. I even tried providing inputs to the FIR once every 80 clock cycles.
CheepinC_altera
4 months agosaasha Would you mind to help to create a simple testbench design in QuestaSim that reproduces the issue you’re observing? Having a minimal simulation case would greatly help with replication and debugging on our side.
It would also be helpful if you could share the step-by-step procedure to run the simulation. Additionally, please let us know the specific device you are using.
Thank you for your support.
