saasha
4 months agoFIR IP configured for Interpolation
Why does my Altera FIR IP, configured for interpolation by 80, produce the expected outputs when I provide 3 input samples, but fail to produce the expected behavior when I provide 10 input samples? ...
JeffC_Altera
4 months agoJust a thought - if you specify 6.25M input sample rate and a clock rate of 500M, you are specifying an oversample rate of 80x. This implies that you should see an input sample 1 in every 80 clock cycles on the input (and then receive full rate data @ 500M on the output). You are likely overflowing the FSM inside the IP. With that said, I believe you should be seeing tready go low. What version of Quartus / IP are you using here?
