12 years ago --- Quote Start --- Yes, but as you havent included the delay counter on the diagram, you cannot see whether the counter is at 0 yet. Given it has just changed state 5 clocks previous, and needs 10 clocked before changing again, I suspect the counter isnt at 0 yet, hence cannot change state. --- Quote End --- I have added counter output to my waveform and the issue is there. I will post correct code when debugged.
