OrF
2 years agoFind where false_path was set.
Hi, I have a design where there is a physical path between two flip-flops (FF). However, when I try to generate a timing report, the Timing Analyzer shows “nothing to report.” I assume this might be...
OrF
1 year agoHi,
I tried the additional step you suggested, but it still doesn’t resolve the issue. I used the command write_sdc -expand "expanded_sdc.sdc", but the output still includes lines like the following on the false path, and I don’t see it expanding the output delay constraints:
set_false_path -from [get_clocks {rx_*}] -to [get_clocks {pll_*}]
set_output_delay -add_delay -max -clock [get_clocks {tx_clk}] 47.000 [get_ports {DIE0_dib_pad_0_*_*[*]}]
set_output_delay -add_delay -min -clock [get_clocks {tx_clk}] 0.000 [get_ports {DIE0_dib_pad_0_*_*[*]}]
Any further suggestions?
Or.
