OrF
2 years agoFind where false_path was set.
Hi, I have a design where there is a physical path between two flip-flops (FF). However, when I try to generate a timing report, the Timing Analyzer shows “nothing to report.” I assume this might be...
sstrell
1 year agoIf you want to expand all wildcards to a separate file, the correct command is
write_sdc -expand "<sdc file name>"
