OrF
2 years agoFind where false_path was set.
Hi, I have a design where there is a physical path between two flip-flops (FF). However, when I try to generate a timing report, the Timing Analyzer shows “nothing to report.” I assume this might be...
OrF
1 year agoHi,
Unfortunately, it didn’t help.
I’m not sure if I removed the .sdc file you asked me to remove. I removed these two files:
The output of the command the file report_sdc.txt
'report_sdc -file report_sdc.txt'
The .sdc file of the project, but then I couldn’t regenerate the timing report because it looks for the .sdc file in its initial steps.
So, I removed the .sdc file before issuing the command:
Bottom line, neither approach helped.
maybe I don't understand where to remove it .
Or.
