OrF
2 years agoFind where false_path was set.
Hi, I have a design where there is a physical path between two flip-flops (FF). However, when I try to generate a timing report, the Timing Analyzer shows “nothing to report.” I assume this might be...
RichardT_altera
1 year agoTry removing the .sdc file reported in the Report SDC (Set False Path) from the project directory and check if the timing path is reported between the flip-flops.
The asterisk (*) is likely not expanding because the SDC constraints were initially written in that format.
Richard Tan
