OrF
2 years agoFind where false_path was set.
Hi, I have a design where there is a physical path between two flip-flops (FF). However, when I try to generate a timing report, the Timing Analyzer shows “nothing to report.” I assume this might be...
OrF
2 years agoHi
can you point me to the report that expand the wildcard.
since I used the next command (gui or to file)
>report_sdc -file report_sdc.txt
and I still see the wild cards
; Set False Path ;
; SDC Command ; Flags ; From Flags ; From ; Through ; To Flags ; To ; Location ; Comments ;
; set_false_path ; ; -from ; [get_clocks {rx_*}] ; ; -to ; [get_clocks {pll_*}] ; scf_manual_addition.scf:65 ; ;
