11 years ago
final procedure block does not work in ModelSim
SystemVerilog LRM (1800-2012):
--- Quote Start ---
A final procedure executes when simulation ends due to an explicit or implicit call to $finish.
--- Quote End ---
But the final block does not execute in ModelSim Altera Starter Edition 10.1e:cry:
I used the following code:
module test();
initial begin
   # 1 $display("Simulation has been started");
   # 1 $finish;
    end
final
    $display("This should be shown at the end");
endmodule
and this is the output:
# Simulation has been started# ** Note: $finish : C:/.../final_bug.sv(4)# Time: 2 ns Iteration: 0 Instance: /test
    Are you running this code interactively? If so, $finish may be behaving like $stop.
    By "interactively" you mean by using the ModelSim GUI, right?
    By the way did you ever simulate a SystemVerilog code containing a "final block" with ModelSim? if not could you please try it and tell me the results?
    thanks
    Model Technology ModelSim SE qverilog 10.1e Compiler 2013.06 Jun 11 2013
    /u/prod/release/10.1e/modeltech/linux/qverilog final1.sv
    -- Compiling module test
    Top level modules:
    	test
    + /u/release/10.1e/modeltech/linux/vsim -lib work test -c -do run -all; quit -f -appendlog -l qverilog.log -vopt
    #  vsim -appendlog -do {run -all; quit -f} -l qverilog.log -lib work -c -vopt test
    #  ** Note: (vsim-3812) Design is being optimized...
    #  //  ModelSim SE 10.1e Jun 11 2013 Linux 3.0.13-0.27-default
    #  //  Copyright 1991-2013 Mentor Graphics Corporation
    #  //  All Rights Reserved.
    #  //  THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
    #  //  WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS
    #  //  LICENSORS AND IS SUBJECT TO LICENSE TERMS.
    #  Loading sv_std.std
    #  Loading work.test(fast)
    #  run -all
    #  ** Note: $finish    : final1.sv(4)
    #  This should be shown at the end
    Thank You Dave!
    I guess instead of using the GUI, you typed the tcl script and this time the output looks fine.
