8 years agoFIFO Works fine on EDAPlayground but not Quartus
All, The following code works fine and as expected on EDAPlayground, but Quartus has an issue with it. I get the ERROR 10028 Can't resolve multiple constant drivers for nets w_addr and r_addr. ...
8 years ago --- Quote Start --- All, The following code works fine and as expected on EDAPlayground, but Quartus has an issue with it. I get the ERROR 10028 Can't resolve multiple constant drivers for nets w_addr and r_addr. I am treating w_addr and r_addr as a temporary variable that can have a value 0 to 31, (5-bits) Any ideas? Thanks, Keith
// FIFO test in an array specfic for HiDS
// set up for Dual clocks
// one to Write
// one to Read
// also will need to have 2 data busses
// Data IN
// Data OUT
// Extras
// nReset -- CLR on LO
// Empty -- HI indicates empty
module DFIFO_array(D_Out, Empty, D_In, wrclk, rdclk, nrst);
output D_Out;
//output D_Out;
output Empty;
reg D_Out;
//reg D_Out;
input D_In;
//input D_In;
input wrclk;
input rdclk;
input nrst;
// DFIFO for 64 Channel SAM 41 x 32
// EFIFO for 64 Channel SAM 10 x 64
parameter WIDE = 41;
parameter DEEP = 32;
// this should give us a FIFO of 41 bits Wide by 32 words deep
// 9-bit counter in MSB bits 32:41
// 32-bit channel representation in 0:31
reg addr;
//reg addr;
reg w_addr;
reg r_addr;
always @ (posedge wrclk)
begin
addr <= D_In;
w_addr <= w_addr + 1;
end
always @ (posedge rdclk)
begin
r_addr <= r_addr + 1;
D_Out <= addr;
end
always @ (nrst)
begin
if (!nrst)
begin
w_addr <= 0;
r_addr <= 0;
end
end
assign Empty = (w_addr == r_addr);
endmodule
///////////////////////////////////////////////////////////// --- Quote End --- you need to insert the statements: w_addr <= 0; r_addr <= 0; so as to reset them in same top two processes.
