15 years ago
FFT megaCore usage problem
I am using FFT megaCore as the core of my digital spectrum analyzer
FFT core paramters: N=64, streaming mode, 8 bit inputs and output.
However, in the vector waveform file that I made the simulation on FFT megaCore, the source real and imaginary have noise and I just want to capture the output at negative edge of the clock because those values are stable values that I wanted.
I think of using negative edge-triggered D-Flip flop to store value when at the negative-edge of clock by using the source_sop and source_eop to enable the the D-flipflop. but that 2 signal only peaks for a short time.
May I know how can I use this 2 signals to enable the D-flipflop or is there any better way to capture stable values from FFT megaCore?
