Thanks for the guidance on testbench
I have read the example code you provided, so when I make simulation at modelSim, do I need to include all files in the project to run or just put fft_h.vhd and the test_bench_example.vhd?
Do I need to use the command like
FILE file_in : TEXT is in "data_real.txt";
FILE file_in : TEXT is out "dataout.txt";
VARIABLE line_in : LINE:
VARIABLE line_out : LINE'
VARIABLE input_tmp : INTEGER;
VARIABLE output_tmp : INTEGER;
and command like READLINE()
for declaring the input and output files to provide inputs and obtain output of FFT when using the testbench file you provided?
I notice there is a file fft_h_tb.vhd generated by the FFT megaCore, what is the difference between these 2 files fft_h_tb.vhd and fft_h.vhd?
I also attached the all vhd files of my project. let me know what I should do to improve my vhd coding and integrate the simulation command to them? Thank you.
