Karthi_S
7 years agoFatal Error: RUNTIME_0033 altera_mf.vhd (14081) Negative waveform time expression
Does anyone experienced the following fatal error in altera + aldec environment?
KS
- KennyT_altera
Which version of Aldec Riviera-PRO Simulator and Quartus version that you were using?
This might be the case both version are not compatible.
- Karthi_S
I am using Active-HDL-10.4a and Quartus Prime 17.0 Standard Edition.
- KennyT_altera
In that case, you may have to downgrade the version of your Active HDL 10.3. Also Active HDL support for windows only.
You will also need to upgrade to Quartus Prime 18.1 Standard Edition.
Check on https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn-qts-std-dev-support.pdf page 7
