Karthi_S
7 years agoFatal Error: RUNTIME_0033 altera_mf.vhd (14081) Negative waveform time expression
Does anyone experienced the following fatal error in altera + aldec environment? Fatal Error: RUNTIME_0033 altera_mf.vhd (14081) Negative waveform time expression Thanks KS
KennyT_altera
7 years agoWhich version of Aldec Riviera-PRO Simulator and Quartus version that you were using?
This might be the case both version are not compatible.
Karthi_S
7 years agoI am using Active-HDL-10.4a and Quartus Prime 17.0 Standard Edition.
