Karthi_S
7 years agoFatal Error: RUNTIME_0033 altera_mf.vhd (14081) Negative waveform time expression
Does anyone experienced the following fatal error in altera + aldec environment? Fatal Error: RUNTIME_0033 altera_mf.vhd (14081) Negative waveform time expression Thanks KS
KennyT_altera
7 years agoIn that case, you may have to downgrade the version of your Active HDL 10.3. Also Active HDL support for windows only.
You will also need to upgrade to Quartus Prime 18.1 Standard Edition.
Check on https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn-qts-std-dev-support.pdf page 7
