17 years ago
fan out problem in assigning
I want to implement a CAM/RAM combination.
the altera megawizard function dosn't provide a seperated bus CAM for (read_data & write_data)
I have to send incoming_label to both: CAM and CPU but I facing with fan_out problem in assignment.
providing input/output registering for CAM dosn't work
how can i fix this problem?
currently i don't want to design a new CAM device with separated bus.
thanks.
http://www.freeimagehosting.net/uploads/th.27decd1759.jpg (http://www.freeimagehosting.net/image.php?27decd1759.jpg)
    You may design a bus multiplexer block which reads simultaneously the label_out and the output of the CPU and enables the output automatically when one of the two inputs has to be passed to the CAM-RAM block. In this way the two input busses will not feed the input simultaneously, thus avoiding the problem.
    yes thanks, I solved it after posting this thread with bus_mux in megafuncions it was very easy and exactly as you said, but I afraid about time conflicts with an interval between two components I though that using a MUX between two components limits my f_max more....but now I think just two main approach remains:
    redesigning the CAM with separated bus for writing and reading or using a MUX.
    the first approach will take long time to design if I want to implement comparable CAM with ALT_CAM megafunction in a synthesis perspective.
    so I have to sacrifice the f_max for this.
    actually if I don't mistake on these thoughts, but sincerely thanks for your comment that's exactly a right solution.
    Best Regards
    You are right, you will certainly see a decrease in the fmax, but typically the overall performance will be mostly dependent on the memory access time so you won't see a high decrease only for the presence of the bus multiplexer.
