Failed to create DisplayPort IP Core Example Design under Windows
- 1 year ago
Hi spte,
Thank you for the updates. My apologies for the delayed response, I was out of the office.
Yes, please upgrade the IP core when using the newer Quartus version after generating the design example in the older Quartus version (18.1). It should work properly.
Please let me know if there are any issues with upgrading the IP cores in the design example.
Ven
Dear ventt
Thanks for investigating.
I'm one step further now: I had to go down to version Quartus 18.1 Lite. With this version, I could create the DP example design.
It seems, that the flow requires Cygwin to be installed. 18.1 was the last Quartus version using Cygwin.
Since this version (so also the core) is quite old, I now have several options:
- Converting the the pre-compiled project up to a newer Quartus Version and updating the core
- Find out how to use Cygwin to create the core with a recent Quartus version
- Figure out what was the problem with using WSL with the recent version
Hope you bring a bit light into this.
Thanks in advance
spte
