12 years ago
Executtion error
I successfully compiled the sample kernel vecAdd.cl file.
I also did a make on the Makefile.linux file.
when I run the executable using command ./vecAdd_host
I get the following error:
$ ./vectorAdd_host
PCIe-MMD Fatal: Version mismatch, expected 0 but read aaaaaaaa
vectorAdd_host: acl_pcie_device.cpp:214: ACL_PCIE_DEVICE::ACL_PCIE_DEVICE(ACL_PCIE_BOARD*): Assertion `0' failed.
Aborted
How should I resolve this error?
    Given your other post about flash programming, I'm suspecting that the there isn't a valid OpenCL hardware image programmed into flash. Essentially for the OpenCL tools to work correctly there needs to be a valid OpenCL hardware image burned into flash so that the tools/runtime can communicate to the board.
    I am actually using the board remotely.
    I have confirmed that the board is from the Nallatech vendor.
    When I target the compilation to any of the two nallatech board package pcie385n_a7 or pcie385n_d5 using aoc --board <board package> command I get the following compilation error.
    $ aoc --board pcie385n_a7 -v ./vectorAdd.cl
    Error: Quartus compilation FAILED
    See quartus_sh_compile.log for the output log.
    I did look into the quartus_sh_compile.log file and I see the following error lines. Is there a way to resolve it ?
    I am using the system remotely with centos distribution and the RAM size is around 13 GB.
    *** Fatal Error: Segment Violation at 0x139840ffbc9
    Module: quartus_map
    Lock in use: 55
    Stack Trace:
    0x14d7f3: CDB_SGATE_NETLIST::dfs_visit_oterm(CDB_SGATE_OTERM*, _Dinkum_std::vector<CDB_SGATE_NODE*, MEM_STL_ALLOCATOR<CDB_SGATE_NODE*> >*, int*, bool, bool, _Dinkum_std::vector<CDB_SGATE_NODE*, MEM_STL_ALLOCATOR<CDB_SGATE_NODE*> >*) + 0x33 (db_cdb_sgate)
    0x14e375: CDB_SGATE_NETLIST::dfs_from_outputs(bool, bool, bool, _Dinkum_std::vector<CDB_SGATE_NODE*, MEM_STL_ALLOCATOR<CDB_SGATE_NODE*> >*) + 0x2e5 (db_cdb_sgate)
    0x13fb40: CDB_SGATE_NETLIST::dfs(CDB_IO_TYPE, bool, bool, bool) + 0x30 (db_cdb_sgate)
    0x13fe0e: CDB_SGATE_NETLIST::garbage_collect(bool) + 0x5e (db_cdb_sgate)
    0x14ffa7: CDB_SGATE_NETLIST::sweep() + 0x5f7 (db_cdb_sgate)
    0xf4c07: RTL_OPERATOR::cherry_pick_6lut_roms(CDB_SGATE_NETLIST*) + 0x2d7 (synth_opt)
    0xf8e2a: RTL_OPERATOR::family_aware_crack_muxes(CDB_SGATE_NETLIST*) + 0x8a (synth_opt)
    0x8ab81: RTL_OPERATOR::exit_process_muxes(CDB_SGATE_NETLIST*, CDB_SGATE_HIERARCHY*) + 0x51 (synth_opt)
    0x8ae32: RTL_OPERATOR::exit_cleaning(CDB_SGATE_NETLIST*, CDB_SGATE_HIERARCHY*, bool) + 0x112 (synth_opt)
    0x169b93: RTL_SCRIPT::call_common_rtl_fns(char const*, char const*, char const*) + 0xd33 (synth_opt)
    0x16666d: RTL_SCRIPT::call_named_function(char const*, char const*, char const*, int, int, int) + 0x2fd (synth_opt)
    0x168072: RTL_SCRIPT::process_script(CDB_SGATE_NETLIST*, CDB_SGATE_HIERARCHY*, BASEX_ELABORATE_INFO*, CMP_FACADE*, RTL_SCRIPT_ENUM, char const* (*) [3], int, RTL_SCRIPT_STEP*, RTL_SCRIPT_STEP*) + 0x5b2 (synth_opt)
    0x417ad: opt_process_netlist_scripted(CMP_FACADE*, CDB_SGATE_HIERARCHY*, BASEX_ELABORATE_INFO*, RTL_SCRIPT_ENUM, bool) + 0x35d (synth_opt)
    0x4256f: RTL_ROOT::process_sgate_netlist(CMP_FACADE*, CDB_SGATE_HIERARCHY*, BASEX_ELABORATE_INFO*, RTL_PASS_ENUM) + 0x39f (synth_opt)
    0x147fd2: SGN_SYNTHESIS::high_level_synthesis() + 0x112 (synth_sgn)
    0x148252: SGN_SYNTHESIS::process_current_stage() + 0x132 (synth_sgn)
    0x175b87: SGN_EXTRACTOR::synthesize_partition(unsigned long) + 0x467 (synth_sgn)
    0x176b57: SGN_EXTRACTOR::synthesis() + 0x1f7 (synth_sgn)
    0x17e98a: SGN_EXTRACTOR::synthesis_and_post_processing() + 0x31a (synth_sgn)
    0x17ebe1: sgn_qic_helper(CMP_FACADE*, _Dinkum_std::vector<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >&) + 0x171 (synth_sgn)
    0x2ba51: qsyn_execute_sgn(CMP_FACADE*, _Dinkum_std::vector<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >, MEM_STL_ALLOCATOR<_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > > >&, _Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > const&) + 0x421 (quartus_map)
    0x39b7c: QSYN_FRAMEWORK::execute_core() + 0x17c (quartus_map)
    0x3a8d7: QSYN_FRAMEWORK::execute() + 0xaa7 (quartus_map)
    0x179ee: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x342 (comp_qexe)
    0x2111d: qsyn_main(int, char const**) + 0x6d (quartus_map)
    That's not enough RAM to compile for a Stratix V - A7 device. At a minimum I would target a system with 24GB of main memory and make sure that system isn't multitasking a bunch of other memory intensive applications during the compilation. I compile mostly on Windows 7 and see my system memory requirements peak at around 22GB on some kernels targetting that board so compiling on a 32GB machine would be safer.
    --- Quote Start ---
    $ ./vectorAdd_host
    Aborted
    --- Quote End ---
    Are you using $aocl program vectroadd.aocx to burn .Sof into fpga directly?
    Have you solved this problem? I am facing the same one? Need your help! Thanks!!
    Yuxuan
