--- Quote Start ---
I successfully compiled the sample kernel
vecAdd.cl file.
I also did a make on the Makefile.linux file.
when I run the executable using command ./vecAdd_host
I get the following error:
$ ./vectorAdd_host
PCIe-MMD Fatal: Version mismatch, expected 0 but read aaaaaaaa
vectorAdd_host: acl_pcie_device.cpp:214: ACL_PCIE_DEVICE::ACL_PCIE_DEVICE(ACL_PCIE_BOARD*): Assertion `0' failed.
Aborted
How should I resolve this error?
--- Quote End ---
Are you using
$aocl program vectroadd.aocx to burn .Sof into fpga directly?
Have you solved this problem? I am facing the same one? Need your help! Thanks!!
Yuxuan
