Executing a user added TCL script
If I write the following 2 lines of code inside Quartus TCL console:
set f [open d:/some_file.vhd w] close $f
I get a file named "some_file.vhd" created in d:/ of my PC.
I wanted this file to be created every time I run compilation - so my idea was to write these two lines inside a TCL file named: "some_script.tcl" and add this file to my Quartus project as a source file.
I did that but it doesn't work. It seems like the script inside the TCL file doesn't run and the file isn't created.
What did I do wrong ?
- mfro
That's not how it works.
If you want to execute a specific .tcl script everytime you start the Quartus compilation process (which is what I understood you wanted to do), you need to manually add another line to your <project>.qsf file:
set_global_assignment -name PRE_FLOW_SCRIPT_FILE "quartus_sh:<your_tcl_file>.tcl"
- SyafieqS
Hi Kon,
You may refer to below links for Quartus II Tcl Example: Automatic Script Execution
In your case, you have to modify your .qsf file and add following line
