11 years agoError with LMP counter component..
Hi all,
I have a design where I use the LPM_counter as a component "offline". But, I get an error, which to me does not give any meaning... (See below text). Does anyone have an idea of what I am doing wrong here... Best Regards: Martin C. tools: I am using Quartus 2 ver. 14.02.209. 64-bit. Top_level vhd file is attached. offline vhd file is attached. The error points to line 236 of file: lpm_counter.tdf (also attached_changed extension for upload). below is complete message read out from analysis: --- Quote Start --- Info: ******************************************************************* Info: Running Quartus II 64-Bit Analysis & Synthesis Info: Version 14.0.2 Build 209 09/17/2014 SJ Web Edition Info: Processing started: Tue Nov 04 14:11:56 2014 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off DMB512 -c DMB512 Info (20030): Parallel compilation is enabled and will use 4 of the 4 processors detected Info (12021): Found 2 design units, including 1 entities, in source file fsm.vhd Info (12022): Found design unit 1: FSM-Behavioral Info (12023): Found entity 1: FSM Info (12021): Found 2 design units, including 1 entities, in source file top_level.vhd Info (12022): Found design unit 1: Top_level-Top_level_architecture Info (12023): Found entity 1: Top_level Info (12021): Found 1 design units, including 1 entities, in source file dmb512.bdf Info (12023): Found entity 1: DMB512 Info (12021): Found 2 design units, including 1 entities, in source file filter.vhd Info (12022): Found design unit 1: Filter-Behavioral Info (12023): Found entity 1: Filter Info (12021): Found 2 design units, including 1 entities, in source file clockcounter.vhd Info (12022): Found design unit 1: ClockCounter-Behavioral Info (12023): Found entity 1: ClockCounter Info (12021): Found 2 design units, including 1 entities, in source file tb_clockcounter.vhd Info (12022): Found design unit 1: tb_ClockCounter-behavior Info (12023): Found entity 1: tb_ClockCounter Info (12021): Found 2 design units, including 1 entities, in source file send_p.vhd Info (12022): Found design unit 1: send_p-Behavioral Info (12023): Found entity 1: send_p Info (12021): Found 2 design units, including 1 entities, in source file offline.vhd Info (12022): Found design unit 1: offline-SYN Info (12023): Found entity 1: offline Info (12127): Elaborating entity "DMB512" for the top level hierarchy Info (12128): Elaborating entity "Top_level" for hierarchy "Top_level:inst" Info (12128): Elaborating entity "ClockCounter" for hierarchy "Top_level:inst|ClockCounter:Clock4800" Info (12128): Elaborating entity "ClockCounter" for hierarchy "Top_level:inst|ClockCounter:Clock1200" Info (12128): Elaborating entity "ClockCounter" for hierarchy "Top_level:inst|ClockCounter:LED_dimmer" Info (12128): Elaborating entity "Filter" for hierarchy "Top_level:inst|Filter:P1Filter" Info (12128): Elaborating entity "FSM" for hierarchy "Top_level:inst|FSM:STATEMACHINE" Info (12128): Elaborating entity "offline" for hierarchy "Top_level:inst|offline:offline_comp1" Error (287127): Text Design File syntax error: Text Design File contains '(' where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error (287127): Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error (287127): Text Design File syntax error: Text Design File contains a symbolic name where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error (287127): Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error (287127): Text Design File syntax error: Text Design File contains ELSE where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error (287127): Text Design File syntax error: Text Design File contains ELSE where ASSERT, CONSTANT, DEFINE, DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 6 errors, 0 warnings Error: Peak virtual memory: 548 megabytes Error: Processing ended: Tue Nov 04 14:11:59 2014 Error: Elapsed time: 00:00:03 Error: Total CPU time (on all processors): 00:00:02 --- Quote End ---
