Legacy devices were dropped with Quartus version 9.1, You will need to install Q9.0 to compile for this device.
i'm not sure about that
the Release Notes and Web Edition Comparison both show "All MAX devices" as supported, and i see MAX3000A in 11.1sp2 Subscription Edition - Altera_Forum
I found the 9.0 version and set up my project the same way and it compiled with out that issue. I'm not sure if 11.1 stopped supporting the MAX3000A or not but I do know that Version 9.0 does work.
I would like to use the newest version, if there is any other reason it might not work please let me know. Thank you again. - Altera_Forum
Yes. It appears Altera dropped several legacy devices, (Max 3000A, original Cyclone's etc) from the webpack, even though they are still supported in the licensed version
Pete - Altera_Forum
the Cyclone is listed as being no longer supported, but not the MAX. i guess they need to fix the doc:
http://www.altera.com/literature/po/ss_quartussevswe.pdf
